The filler over the high density foam inside the rudder horn wasn't thick enough, so the area tended to flex. I was concerned this may crack the paint with temperature changes, so I ground the area out to about 3mm deep and reset with epoxy & Aerosil. When that set, I rasped it back flush, ready for a brush coat of 2K primer.
