I mixed 500ml of primer and re-sprayed the front end of the canopy sills, then sprayed the elevators and rudder. I dwelled a little over the rivet heads again to make them fill. I have quite a lot more sanding and primer to go before I'll be happy with the smoothness. The clear coat will show up everything, so the prep work needs to be good.
