Again the Van's pre-cast lead weights aren't heavy enough for the Rocket, so I filled the washer holes with lead and cast an additional flat weight. It's a bit of a guess, but the elevator seems front heavy enough to account for the paint. I'd rather drill out some lead than have to add more weight later, but I'll put a single nut plate inside the horn to attach more weight later if necessary .... I'd rather leave the options open for now!
