I sanded into the epoxy and Aerosil around the top and bottom fairings and applied a coat of Upol Reface. It will be virtually impossible to make the surface dead flush with the skins below the upper fairing, but it will look OK. I need to decide which rivet lines to leave visible and which to cover up ... I think the front spar rivets need to be hidden for overall appearance.
