I cut two carbon fibre circles from thin sheet I had made previously, turned them true in the lathe and riveted them to the baffle seal to add some weight and keep the seal flat. It worked out pretty well. I may later add a ring to the centre for a micro switch lever so I can tell when the door is open.
