I checked for clearances around the engine and accessories, then slotted the duct to accept the baffle seal and trimmed a piece of carbon fibre angle out of a spare wheel chock. I shaped the angle to match the duct and die-ground to accept a floating # 8 nutplate. I then drilled for two AD3 rivets and set the bracket in epoxy & Aerosil. I have no doubt the attachment will be strong, but even if it were to come off, the parts will float in situ and can't be ingested into the fuel servo.
Later on I may cut a new silicon insert from flat baffle seal so that it sits squarely inside the flange in neutral.
