Stuarts Web Site
Date:  5-20-2012
Number of Hours:  1.00
Brief Description:  02 - Prop cable firewall passthrough
I drilled the firewall for the prop cable passthrough and opened out the eyeball to match the cable shroud. Thankfully there is plenty of cable length, because I need to reposition the governor lever to swing on the bottom and re-make the cable support bracket to point the rod-end in the right direction.
