Welded the C-frame together per the plans, but with the addition of a flat bar strap running full height up the spine of the frame (mostly for cosmetic reasons - to block off the open tubes). The beams are so large that the edge radius took a lot of TIG filler wire (I will grind everything flush before sandblasting and painting).
Ground the sides flush and painted with hammertone finish.
