Brief Description: Intercylinder baffles and DRDT2 C-frame
Intercylinder Baffles and DRDT2 C-Frame Construction
Cleaned the intercylinder baffles, drilled out the rivets holding the attachment bracket, Alumiprep'd and Alodined, then re-riveted the attachment brackets on.
Made the initial cuts for the top and bottom beams for the DRDT2 C-frame (having imported only the front-end kit - thank goodness, since the framework is made from 6" x 3" steel, is huge and weighs a ton).
