Stuarts Web Site
Date:  10-16-2022
Brief Description:  01 - Upper Gear Intersection Fairings (UGIF)
I spent some time shaping the inside rear of the starboard UGIF to fit the GLF, removing excess in the area where I had bonded the trailing edge back together. A hacksaw blade proved very useful in this circumstance. When that was done I sanded and primed the UGIFs inside and out, then reprimed. I think this time all the pin holes will be gone from the outside, so I'm almost ready to match the trailing edges to the wing root fairings (once they're drilled and cleco'd to the fuselage).
