Brief Description: 01 - Upper Gear Intersection Fairings - port
Upper Gear Intersection Fairings (UGIF) - port
It was considerably more difficult than expected to remove the layup from the wax, so I had to slit the front of the fairing to get it off. Once that was done I cleaned off all the wax and reinforced the inside trailing edge with additional carbon so I can shape the edge exactly to the curve that looks best. When I'm done finalising the overall shape, I'll bond the front together with more carbon in place on the gear leg, after which I will need to remove the axle to get it off for finish painting, which is fine.
