Stuarts Web Site
Date:  9-13-2009
Number of Hours:  0.01
Brief Description:  FOR SALE - Adel clamp pliers AUD - $45pr
Adel clamp pliers
Makes fitting multiple Adel clamps much easier. Use an ice pick for initial clamp alignment, then pinch with the locking pliers, remove the pick, fit the nut and bolt ... too easy!
Quality 4" locking pliers to fit into tight spaces, laser cut stainless steel inserts, TIG welded with stainless wire and retouched with zinc rich paint. Suits up to AN3 size screws or bolts.
Ideal around engine mount, fuel injector lines and fuselage truss areas!
$45 plus postage, or supply your own locking pliers and I'll modify them for $30 plus postage.
