Brief Description: 01 - Wing root fairings and LGIFs
I sanded both wing root fairings and the LGIFs then primed with another coat of 2K. When that dried I sanded again, then drilled and filled the last remaining pin holes on the wing root fairings. Tomorrow I'll sand the filler smooth and hopefully add the last coat of 2K before drilling to the fuselage for #8 screws and tinnerman washers so I can start match moulding the aft fairings.
