Tonight I ground the sharp edges off the carbon reinforcements inside both wheel pants, then fitted the nutplates to the starboard bracket and rough-trimmed the opening around the tyre. The hole for the inflaction valve access cover was a little out of alignment, so I waxed and set that in a thin bead of epoxy/Aerosil to match mould. Tomorrow I'll grind the tyre cutout smooth, free the access cover, sand and prepare for drilling mounting holes and nutplates for the lower gear intersection fairings.
