I made some minor adjustments to the alignment of the wheel pants to match each other. This required very slighly elongated holes in the carbon flange (sandwiched between the axle and gear leg socket) to drop the rear of the right pant by 15mm and a slight axial rotation of the left pant to adjust the vertical alignment of it's trailing edge. I'm happy with the results, so will fill the old holes next and add reinforcement. Then I can crack on with installing the intersection fairings.
