I separated the new brackets from the moulds and rough trimmed, then match drilled to the wheel pants and trial fitted. There's still a bit of final alignment work to do once I check the toe-in at roughlly 1600lbs AUW (the procedure has changed since I drilled the axle sockets 14 years ago). For that I'll need the SAAA scales, weight tray and grease plates.
