After three years of curing, I finally sanded the pin-hole filler off the front halves of the wheel pants. Tomorrow I'll die-grind the inside layup overlaps for a better fit with the aft sections and start measuring, trimming and fitting the pants to the lower mounts. These take a pounding on uneven surfaces, so I'll reinforce the insides around the mounting points with one or two layers of 200GSM carbon as well.
