After borrowing the ring compressor and front-end tool, James and I swapped out the probelm tappet bodies, installed the new oil seal, reassembled the case halves around the crank and camshafts, then installed the pistons and cylinders ... torquing in accordance with the Lycoming overhaul manual.
