I chased some more pin holes and fine sanded the outside of the upper cowl, then filled all the pin hiles on the inside with fine body filler. I've decided not to use a plenum, so the baffle seals will need a smooth surface to seal against. It's also quite a visible area looking in through the intakes and also when the cowl is removed, so a little TLC here is worth it.
