I anticpated the new GTX-345 would be a slide-in replacement for the GTX-327, but no, the rear screw holes are in a different position. So, I had to remove all the racks, remove the cradle from the panel, drill out the old nutplates, install new ones and match-cut diamond-shaped holes for screwdriver access on the inside and the cooling outlet hole as well.
