Stuarts Web Site
Date:  8-8-2018
Number of Hours:  0.50
Brief Description:  03 - ELT anntenna mount bracket
I vacuum bagged a carbon fibre doubler to mount so that I don't have to disconnect the BNC from inside the fuselage before removing the ELT antenna. This will also need silicone flex joint to avoid stress on the skin as the dorsal fin is installed over the leading edge of the horizontal stabiliser. I think the absence of a positive ground plane connection to the fuselage will be acceptable given data-bursts are at 5W, only need to be received once by one COSPAS/SARSAT satellite and that the unit can be operated hand-held or free standing on the ground.
