I rip-sawed some square balsa wood down the middle to make triangular section, cut to size and glued together to form ribs in the floor panel doors. These will be sandwiched into the door panels around the Hartwell latches and should cause enough stiffness in the carbon fibre to stop excessive flex in doors when stood on.
