Red is done. I'm using 2K solid instead of 2K base in this instance because of the undulations in the skin, which will allow me to do slightly more aggressive sanding without cutting through to the white primer. Next I''ll mask off for the black to butt against the red (easier to see with contrast) and then I'll fill in the remaining space with Stark White (a Ford colour), since brilliant white is too hard on the eyes in bright sunlight.
