James and I marked, drilled, die-ground and sanded holes for the two cabin-heat punkah louvers in the pilot footwells. They can be aimed foward, back, up or down as required; or closed to force more air up to the windshield defrost, although windsheild defrost will need to be used sparingly to avoid cracking the perspex!
