I installed the elevator trim and servo, ran the motor full in and out with a 9V battery and marked and cut the stainless all thread to length. Once that was done I linished and polished the end of the rod, installed and re-checked the travel. The trim motor can run further than needed, but if I recall correctly, I should be able to set the limits via the EFIS. Either way, the trim deflection is more than ample, so there shouldn't be any need to reach the limits.
