I spent some time drilling and filing the remaining holes for warning lights, dimmer pots and the panel-mounted USB sockets; then sanded, primed and satin greyed the panel. Once that had set hard, I sanded back the grey with 400 grit wet and dry paper to obscure the remaining visible rivet heads. Next I'll finish coat in satin grey and re-install all the instruments.
