I painted the off-white sections, then waited a couple of hours, added covers to the white sections, removed the covers from the red sections and painted those. Unfortunately, I discovered that it takes much longer for the paint dry before it doesn't stick to the masking paper and plastic. Never mind, I think it will be OK when blocked down very slightly, so I'll press on with the black tomorrow, block sand with the interface pad and clear coat later. It should look very good, but there's lots of fine lining left to do yet!
