Stuarts Web Site
Date:  9-18-2016
Number of Hours:  1.50
Brief Description:  Starboard wing tip
Starboard wing tip
I applied another two layers of carbon fibre in the lower leading edge (internally) to stiffen the underside and propped it out slightly to better match the bottom wing skin I then match moulded the tip into the leading edge of the wing skins with epoxy & Aerosil, screwed the tip in place, taped right up to the edge and applied epoxy & Aerosil in the gap. I'll smooth this transition during the priming and finish painting phase.
