I needed to know that the lower cowl is in exactly the right position (with engine mount sag) before matching the plenum, so we re-installed the prop. The spinner bore alignment is good, but more work is required to make the cowl face parallel to the spinner back-plate (unfortunately all the cowls come this way).
Having the prop on made for a good photo opportunity as well, with and without the canopy open.
