I decided not to waste the remaining ProSeal, so I first removed the fuel drain to confirm everything is OK in that compartment, then drilled for and mounted the rear two cover plates in beds of ProSeal. I got smart and taped up the second cover plate before scraping away the excess ProSeal, which makes for a much tidier appearance afterwards. Tomorrow I'll clean up the rear cover plate with a plastic sealant scraper.
