I mixed a ProSeal Semkit and gooped the remainder of the inner wall fillets in the port tip tank, then fabricated a flange and 10mm pin out of 6061-T6 ally to ProSeal through the front wall. Later this will be used to locate a cable tie to retain the landing light module back in its tapered mounting socket. I may yet do the same to support the landing light cables and fuel vent line.
