Stuarts Web Site
Date:  6-10-2016
Brief Description:  02 - Wing tip tanks
Wing tip tanks
Later, I will need a way to align the ProSeal prep'd inspection panels from the outside while I put the screws through the doubler plate and fuel tank sidewall, so it was a good opportunity to let James do some turning on the lathe! We cut and threaded six Acetal plates, cleaned all the survaces with isopropyl alcohol and bonded them onto the inspection panels with super strong 3M LSE double-sided tape.
