This afternoon James and I bonded the endwalls in place with a VE resin & Aersil mix and cleco'd the tip back to the wing. I need to scuff the resin sheen with 60 grit paper first, then I'll slip a layer of carbon between the upper and lower edges and VR resin that in place for extra grip area (under tension wit fuel in the tank), then lay up corner reinforcement around the seams and widen the fixture flanges for increased screw edge distance. It's coming along nicely ... I can't wait to test the capacity to see how close my guess is :-)
