I re-checked the tip tank wall, then cut two flow holes through the baffles and sanded smooth. I then measured and marked the recess for the lights and cut the parallel section out for relocation 1/2" further inboard as per the other tip that I did a couple of years ago. The extra space is needed to fit the AveoMaxx light with strobe on the side under the plexi cover.
