Stuarts Web Site
Date: 12-9-2014
Number of Hours: 4.00
Brief Description: 01 - HS-015 plate
HS-015 plate
I measured, measured, measured, then match drilled to #40 through the VS into the HS-015. Once that I was done I disassembled everything, upsized the holes in the HS-015 to #12 through a steel guide to relocate them slightly further away from the edge, then match drilled the VS up to #12, (subsuming the old #40 holes completely). I then marked out a pattern of lightening holes, drilled, deburred and polished all the edges, then cleaned, primed and reinstalled to check the fit. All good.
