Brief Description: 02 - Pitot and AoA lines and wires
I checked where the aileron torque tube would run through the wing and connect to the control torque tube to determine where best to install conduit for the pitot and AoA lines, plus power and status wires. Then I marked out the attach points, drilled and blind riveted Panduit brackets into the lightening holes. I used a phenolic washer on each one as a spacer to eliminate any strain. When that was done, I cable tied the conduit in place, except near the bellcrank, where I'll need to trim some more for clearance.
