I installed a 45 degree bulkhead fitting in the second rib so the flexible line can be routed very close to the bottom skin and passed through final rib angled forward toward the bulkhead fitting in the wing tip fuel tank. Otherwise the fuel line would be extremely difficult to install as the wing tip tank is fitted.
