Stuarts Web Site
Date:  6-11-2012
Brief Description:  01 - Fuel flow sensor bracket
I fabricated a bracket to suppor the fuel flow sensor. The sensor needs streamlined fuel flow in and out, so the connectors need to be straight. Airflow Performance are adamant that the sensor needs to be mounted between the fuel servo and the divider for best readings, but this leaves the sensor vulnerable to vibration. Hence, I will mount the sensor bracket with silicone washers to absorb as much vibration as possible. I have also chosen a location as close as possible to the centreline of the engine where the vibration displacement is minimised. There isn't much clearance and although I used a template, this particular chrome-moly bracket isn't going to work out the way I want, so I'll start over.
