I finished making the middle mounting board for relays and the starter vibrator. I needed to think carefully about relay orientation and proximity to avoid interference between the electromagnetic solenoids in the relays (three in use and one spare).
Next I'll add support bolts through the firewall and attach the 80A ANL current limiter and pressure transducer manifold on the firewall side. Then I can make mounting boards for the shunt and other electrical components.
