For the first time in three weeks, winds weren't gusiting to 20 knots--so I called on the neighbors to help me to put the wings on for the first time. Positioned the fuselage inside the garage, close to the double-wide garage door. That gave enough room in the garage for rigight wind installation, with the left wing proturding out the garage door into the driveway. Had to trim the flaperon actualtion tab back about 1/8 th inch, then drilled the two #30 holes in the flaperon torque tubes. Called the neighbors in again to help in wing removal.
left wing hanging out the garage into the driveway
