Brief Description: Attached fuse brackets and attached forward fuse t
Attached nutplates and match hold drilled/attached FT-60 bracket to bottom of fuselage, and attached aluminum angle bracket to front of fuse. Attached fuse shelf to firwall fron using the infamous fuel tank sealer--ugh--genuine unadulterated hookumpuckee. That is some of the grabbiest stuff I've worked with since som wood floor glue... Then attached thie forward fuse assumbly to the remainder of the fuselage bottom.
