Rob and Haruko RV-12 N73HR
Date:  11-24-2010
Number of Hours:  7.00
Manual Reference:  26-2 to 26-4,27-02
Brief Description:  Seat backs construction & rudder pedal assembly
Cut piano hinges and match hole drilled for seat frames, Assembled seat frames.
Began rudder pedal preparation. Discovered that I had 3 Left master cylinders and 1 right master cylinder for the brake pedals---need two of each. Some how or other, also mis-drilled one of the torgue tubes in a way that can't be worked around--will need to order a new part.
Assembled Seat backs
Seat backs installed
Benchtop assembly of rudder pedals
