Brief Description: Finished riveting remaining two upper wing skins o
Finished rivetiing the inboard and middle upper wing skins on the right wing, with the exception of the wing walk area--clecoed and checked the braking I did on the leading edge of the wing walk doubler skin--needs a bit more brake in spots. The countersink dimples make it impossible to brake the edge with either the pliers or the roller--found that clamping the 1/8th inch falt area available on the edge into a vise and slightly bening it with hand pressure seems to work if patient enough.
