Assembled the stall warning subassembly and the two terminal brackets. There was some confusion on the washers--those designated in the plans (NAS1149FN432P and 416P did not appear in the inventory. AN960-4 and -4L are apparently the equivalent parts, but the numbers supplied in the kit are not quite right. Stacking two 4L's makes a 4, so things work, more or less
Attached the subassembly to the wing nose rib (after discovering and correcting improperly mounted nut plates on the rib. I still need to cleco the wing skin in place to make the adjustments.
