Brief Description: Installed static ports and tubing, wiring
Installed the two static ports. They are blind rivets with a very wide head--the rivet is pulled, then using a spring-loaded punch with a narrowed down pin, drove the madrels out of the static port rivets. Then slipped 1/8th inch tubing over the rivet shaft and hookumpukeed in in with RTV. Ran the static tupes together in a tee, connecting to 1/4" tubing that will (evenually go to the panel instrumentation..
