Trimmed the top inboard flap skin so that it would not rub on the fuselage. Drilled and taped the flap pushrod tubes to size. Installed the rod ends. Drilled the hole on the fuselage for the right wing flap pushrod tube, and filed the hole so that the push rod tube, and rod end would not rub on the skin.
