Trim the F-757 gusset as required. Trim the F-721B as required so that the 757 would fit inside. Drilled the 757 gussets to the longerons. Drilled the F-695 gussets that attach the longerons and firewall. Clamped and drilled the gussets to the firewall, and longerons.
