Drilled the master cylinders to the brake pads. Drilled 3 sets of holes for attaching the rudder assy to the longerons. Installed the rudder assy to the fuselage. Fit the F-6118 center rudder pedal brace. Drilled it to the firewall. and to the F-6115 Center Bearing block. Drilled some lighting holes on the center rudder brace. Removed the rudder assy. Clecoed the fwd bottom skin back to the fuselage.
