Roadster's Web Site
Date:  9-13-2006
Number of Hours:  10.00
Manual Reference:  6-1
Brief Description:  Began Vertical Stabilizer
Began work on the vertical stabilizer. Trimmed the flange material off the two rear spar caps. Deburred. Fitted the rear spar caps and rear spar, and assembled all parts (minus the skin) with clecos for a trial fit. Cross-drilled, deburred, and fitted the rear spar caps to the rear spar with Clecos. Began deburring the edges of the rear spar doubler.
Vertical Stabilizer
Vertical Stabilizer
