Brief Description: Applying Blade Leading Edge Tape
After the paint on the tips had dried, it was time to apply the leading edge protective tape.
This tape was purchased from Bruce (http://www.safarinz.com) after he wrote an article in Experimental Helo magazine (see http://www.experimentalhelo.com/) detailing it's application. Reprints may be available from Stu at Experimental Helo.
The tape was a breeze to install when applied per Bruce's instructions. If you use this type of tape, just make sure you use lots of soapy water. it will make the job go much smoother.
Atomizer bottle filled with soapy water, squeegy and blade tape
I used two hand clamps with foam to hold the blade upright.
